the contextual menu to create a playlist
Topic: the contextual menu to create a playlist (Read 1396 times)
February 04, 2023, 00:59:25 »
socve
Dear, I have installed windows10, AIMP v 5.11.2421, when I right-click on a folder that contains mp3, the contextual menu to create a playlist does not appear, which automatically created the list with the name of the folder. Excuse me for my English as a translator goo..
many thanks for everything
Estimados, tengo instalado windows10, AIMP v 5.11.2421, cuando hago clic derecho en una carpeta que contiene varios mp3, no aparece el menú contextual para crear una lista de reproducción, Anteriormente además de crear la lista de reproducción, automáticamente identificaba la playlist con el nombre de la carpeta. Desde ya muchas gracias por todo
Last Edit: February 04, 2023, 14:57:55 by socve
Re: the contextual menu to create a playlist
February 04, 2023, 01:04:25 »
Супермен
Карма: +414/-72
Вы можете дублировать сообщение на своём языке.
___
Выключите
интеграцию
("Integration"). Примените. Включите. Примените.
Если не помогло, то перезагрузить ПК после выключения.
February 04, 2023, 15:09:37 »
socve
Solucionado, gracias
