New User Help!
Topic: New User Help! (Read 2546 times)
New User Help!
March 07, 2022, 21:25:24 »
AWK
Hi. I have just started importing my music into AIMP. It's a great app!
The only problem I cannot solve is with albums with various artists. Instead of one file, it is showing the number of songs as individual files. How to combine them into one?
Thanks!
Re: New User Help!
March 07, 2022, 21:27:59 »
Супермен
Карма: +3116/-70
It seems that your files has built-in or external CUE sheet that used by a player to split the album by tracks. To prevent this, you need to remove the CUE sheet for these files
Re: New User Help!
March 07, 2022, 21:30:46 »
AWK
Thanks, Artem. How do you do that.
Interesting that some work and some do not.
I just converted all the cd's to flac and use this player.
Re: New User Help!
March 07, 2022, 21:36:14 »
Супермен
Карма: +3116/-70
First, make sure that .CUE file was not placed as separate file next to audio file. If it not, open the file in Advanced Tag Editor tool that shipped with the player. Click "edit all fields" button and jump to CUE sheet page. Remove the content and click "Save"
Re: New User Help!
March 07, 2022, 21:37:53 »
AWK
Genius! Thanks, Artem.
Re: New User Help!
March 07, 2022, 22:11:27 »
AWK
Ha! I tried your suggestion and there are no cues. I deleted the album and then ripped it again. Still showing up as 10 individual files. One thing I did notice is these albums are being placed in a folder called "Various Artisits". Not something I set-up so system created?
Re: New User Help!
March 07, 2022, 22:31:24 »
AWK
Here is a little more information. There are 11 songs on the CD with 6 artists. The app thinks it is 6 separate cd's. Each only has the songs from that artisit.
Re: New User Help!
March 08, 2022, 19:27:51 »
Супермен
Карма: +3116/-70
Please, can you explain you issue in more details via screenshots or video?
New User Help!
