I have no permissions to see the video. Please check your settings
It will dump state of the app.
Thanks. It seems the file system response is so slow while player trying to find missed files. Try to switch off this function. Is it solve the issue?
It was always OFF.. doesn't help...
I'm on version 4.7 again... another bigger issue is manipulation with the files and the payer itself.
As you've seen, the player always lagging and crushing..
