Notification problem
Topic: Notification problem (Read 4962 times)
August 28, 2021, 01:51:14 »
Napper
Hello, I have been using aimp for a few days and I think it is the best free player available on Android but I have a little problem with the notifications: some do not want to go away and I do not know how to remove them. Here is a video to better understand :
https://youtu.be/sKCfHkpXqhs
Re: Notification problem
August 28, 2021, 21:08:30 »
Супермен
Карма: +2821/-49
What is your version of player?
August 29, 2021, 00:52:36 »
Napper
Im on v3.10 but I also tried with the beta and the problem was the same.
August 30, 2021, 10:54:43 »
Супермен
Карма: +2821/-49
Please, try to use this build:
https://disk.yandex.ru/d/UK-VNyncts1W-A
But, first restart your device to clean Android's notifications cache
September 02, 2021, 08:40:19 »
Napper
Do you have other link because i dont speak russian ?
September 02, 2021, 08:44:18 »
Супермен
Карма: +2821/-49
You can change page language by clicking the icon in bottom right corner of the page. (Strange, why Yandex does not set language automatically...)
September 02, 2021, 09:00:24 »
Napper
OK, Im going to try this version and i will tell you in some days
September 07, 2021, 10:33:54 »
Napper
I have been using the version you sent me for a few days and the problem no longer seems to exist. Thank you for fixing this bug.
Reply #8 on:
September 07, 2021, 12:06:53 »
Супермен
Карма: +2821/-49
Thanks for information. I glad that issue has been solved.
