https://mega.nz/file/M34ghACS#msgYdUgFgzMlkMeZRLvjJnBoDu8KZi69JZkE0NgwCN8
Very nice skin. Clean and tidy. Is it possible to add a customization option to set the tray icons as in default skin? Play and pause indicators are too small and barely readable on a dark taskbar.
Please add a black background and OC color to all buttons, text and rating stars in the settings.
screenshot please.
https://imgur.com/a/FEnKJWQ
very very good skin. I realy like it. but there is some problems. when I close the files and folders tab on the left, there is no way to take it back. ( the only way : remove and re install the skin :| ) and the next , when I scroll the pllay lists in the verical playlist mode, first go to the last maked playlist and then scroll down ! if you make something that when go to the next play list scroll a little, that be very veryyyy goood. thank for you to make this skin
Hello.how to fix it? win 10 1909aimp 4.7, 5, 4.63840*2160screenshot in the attachment.
