Can you add an option so we can manually set a window size for Aimp so it remembers it when it starts.
Can you explain what scenarios will be resolved via these options? I for example run a multi-monitor setup with different resolution, size and scaling on each monitor. If I turn off the main monitor it forces Aimp into another monitor with a different size and scaling, thus it will get much bigger and the position will be different of course. So when I restart windows into the main monitor Aimp will start in a corner, and the size of its window is tiny. I tried a workaround just like I did with GoldenDict. By setting the skin ini file to read-only, but it turns off read-only by itself when I restart Aimp, thus has no effect.
