AIMP for Android v3.30
AIMP Not Showing In Context Menu.
Topic: AIMP Not Showing In Context Menu. (Read 1597 times)
March 03, 2021, 11:31:57 »
Owens Arvell
Hai, Somebody Help.
Solution, Please!
Re: AIMP Not Showing In Context Menu.
March 03, 2021, 11:37:03 »
Супермен
Карма: +1214/-166
1) Uncheck all options in the "Options \ System \ Integration" page
2) Apply changes
3) Restore options state in the "Options \ System \ Integration" page
4) Apply changes
March 03, 2021, 11:40:20 »
Owens Arvell
Cheers! Works Perfectly! You're A Life Saver...
Thank You So Much!
March 04, 2021, 07:16:52 »
Turk303
Карма: +1/-0
I was going to say if you get ANY issues with contextual menu check out EcMenu (current version 1.6 & there's a 64 bit version) at sordum dot org.
Enables you to add, remove and best of all a proper "refresh" of CMM's
Also "SendToEditor" (x64) is another useful tool allowing you to easily add send to (surprise surprise) cmm's for apps without a contextual menu option.
Both are available direct from the excellent free utilities site Sordum dot org.
Another consideration would be "Configure FileMenus Tool" although not free it's free licence is still great.
December 15, 2021, 21:50:11 »
der_unkreative
Hello, same problem. Where can I find "Options \ System \ Integration"?
