Windows Properties Suddenly lost
Topic: Windows Properties Suddenly lost (Read 1814 times)
January 25, 2021, 00:27:00 »
locomotive_opus
I am using this app for years, while i haven't changed any setting or install another media player program, suddenly i can't see when i right-click, the options of AIMP like "Add to playlst", "Play Now" etc.
Untill some hours ago, i had those options in my PC. Can somebody help me, i also checked the "Open With" plugin but that wasn't the issue. I'm kinda lost, so if someone can help
- aimp latest version.
- windows 10, i haven't perfomed any update for months.
Last Edit: January 25, 2021, 01:54:55 by locomotive_opus
Re: Windows Properties Suddenly lost
January 25, 2021, 03:08:38 »
ㅤ
Карма: +76/-1
locomotive_opus
Hello and welcome to the forum!
Please, check in your profile folder (for instance:
C:\Users\[your_Windows_username]\AppData\Roaming\AIMP
) if the
AIMP-ContextMenu.ini
file is there.
Kind regards.
January 25, 2021, 13:46:07 »
locomotive_opus
Hi, thanks for the reply. Yes i have the "AIMP-ContextMenu.ini" file.
January 25, 2021, 15:45:57 »
ㅤ
Карма: +76/-1
Have you already tried rebooting your computer?
January 26, 2021, 01:01:47 »
locomotive_opus
I've rebooted my computer several times, installed the program several times also. I've also changed multiple times the default music player but yet nothing changed.
January 26, 2021, 07:46:42 »
Тестер 2-го уровня
Супермен
Карма: +408/-7
Скрытая угроза
Try this:
https://www.aimp.ru/forum/index.php?topic=65692.msg405577#msg405577
Preferences -> System -> Integration -> uncheck the box "Add to Explorer context menu" -> Apply -> then check the box "Add to Explorer context menu" -> Apply -> OK
January 26, 2021, 14:59:55 »
locomotive_opus
I've also tried that, nothing changes.
Thanks for the reply.
