1. At playlist screen: Click the button with 3 vertical dots \ Import playlist.2. At playlist screen: Click the "+" button, and select required folders or files.
Switch to standard theme
How can I import existing *.m3u playlists in AIMP for Android?I found how to create a new, empty playlist but no way to import an existing.The only workaround I found is to go to an external File Manager and "open with" an *.m3u file with AIMP.Is this really the only way?Assume I create an empty playlist: How can I add *.mp3 files?Thomas
I switch the skin and suddenly it works (for ALL other skins).Very interestingMy old Skin was installed years ago. It was sufficient so far. New AIMP Mobile Releases were installed several times and introduced new features. But they didn't work with old Skin.AIMP should add a "check if skin update available" option and inform the user.How exactly can I find out the version of the currently installed (NOT: available) Skin (NOT of AIMP)?I found no info entry in settings
