Very lovely made skin. Great work. Now it's my default skin ^_^
Made an account just to say thank you for this skin....It's absolutley perfect for my use (TV above my PC monitor, used as a media center)Could it be possible to preview the next track with a small album art and track Info? Maybe next to the the skip button?
Hmmm... Maybe it's not easy to add that feature , but I will try to working on it. Thanks for suggestion and #StaySafe !
tray icon?
Hello, thank you for creating this amazing Skin!! It became my default skin because it's almost exactly as I always wished!! Thank you for putting so much effort into this! It is really wonderful!I'm a completely begginner and failed to create my own skin, I gave up in 10 minutes after struggling to do anything. I'm not asking to you to make these changes but I rather want you to tell me if doing these things are possible because I want to try by myself. There is three things I would like to change. When I click "Open playing now" it shows just like the first picture. It would be way better and prettier if the background use the original quality of the picture and at the same time, maintaining the proportion/aspect of the picture (just like the second picture). The second change is the font of letters. There is a way to change it?The last one I would like to create is the option to toggle on/off the playlist on the right side (with keyboard shorcut), something like the last picture (maintaining the proportion/aspect of the cover art and background).Again, I'm not exactly asking for you to do this, I just want you to tell me if it's possible to make those changes... Thanks you
Thanks for the great skin, discovered it today seeking for higher-DPI replacement for W8 Dark. Chroma looks great, the only disappointment is too small tray icon (2560x1440), is it possible to make it a little larger/informative?
Alright, I'll try to make it a little larger.
