AIMP for Android v4.00
Suggestions
DennoN
AIMP for Windows & AIMP for Android user agent strings
Topic: AIMP for Windows & AIMP for Android user agent strings (Read 44771 times)
November 30, 2019, 09:42:53 »
ㅤ𝙆𝙉𝙏𝙍𝙊
Карма: +76/-1
Hi! You can email me or contact me via Telegram.
Hi everyone,
I would like to talk about the AIMP's UA strings, as for Windows as for Android.
Humbly, I would like to suggest adding these user agent strings below to each AIMP build, so we have these:
Suggested default user agent strings for AIMP for Windows
AIMP/4.60
[already included]
AIMP/4.60 (Windows NT 10.0)
Mozilla/5.0 (compatible; Windows NT 10.0) AIMP/4.60
[custom UA option] [already included]
Suggested default user agent strings for AIMP for Android
AIMP/3.0
AIMP/3.0 (Android/8.1.0)
[already included]
BASS/2.4 (compatible; Linux; Android 8.1.0; Mobile) AIMP/3.0
For both cases (Windows & Android):
(1) This string says: "Hey, this is who I am". This is the simplest user agent string.
(2) This string says: "Hey, this is who I am, and if you want to know in what platform do I work, now you know". This string includes not only the AIMP version, but the OS name and OS version as well.
(3) This string says: "So, you don't know what AIMP is, and therefore don't you allow me to stream? OK, here I include some more popular references if you need some well-known standard things". This string is probably the most standard-compliant.
By the way, these user agent strings below (from the Windows' build) should be removed:
Deprecated, useless user agent strings
Mozilla/4.0 (compatible)
Mozilla/5.0 (BASS/2.4; ru-ru) AppleWebKit/533.1 (KHTML, like Gecko)
Please, remember all these things are just my humble suggestions. Please, don't take it so serious —I'm just trying to help AIMP becoming more widely compatible, globally.
Last Edit: November 30, 2019, 13:45:28 by oɹʇuʞ
Re: AIMP for Windows & AIMP for Android user agent strings
December 01, 2019, 13:23:25 »
Супермен
Карма: +3107/-70
You are absolutely right, but it not so easy as it looks at first time. AIMP's settings are too easy - you just specifies the user-agent string and done, but all version codes in it must be dynamically changes depended what player's version, what OS's version where app is running. Mobile version, even does not have a list of predefined templates for that...
December 02, 2019, 02:35:54 »
ㅤ𝙆𝙉𝙏𝙍𝙊
Карма: +76/-1
Yes, I understand. But is it not possible to make user agent strings as follow?
AIMP/4.60 (Windows NT x.x)
Mozilla/5.0 (compatible; Windows NT x.x) AIMP/4.60
AIMP/3.0 (Android/x.x)
BASS/2.4 (compatible; Linux; Android x.x; Mobile) AIMP/3.0
I mean, just let the system replaces the
x
by its custom values. Some examples of 4 diferent OSes (2 desktops and 2 mobiles):
AIMP/4.60 (Windows NT 6.1)
Mozilla/5.0 (compatible; Windows NT 6.3) AIMP/4.60
AIMP/3.0 (Android/9)
BASS/2.4 (compatible; Linux; Android 10; Mobile) AIMP/3.0
December 02, 2019, 07:56:50 »
Супермен
Карма: +3107/-70
Yep, or add the %VER macro
Suggestions
DennoN
