1.0.5
Right after a crash (before restarting AIMP) go to C:\Users\[User]\AppData\Roaming\AIMP\aimp_youtubedl and upload here the aimp_youtubedl.log file.
What exactly doesn't work? Do you mean that it still just plays 30sec? How did you obtain the cookies.txt (do NOT upload the file anywhere though)? Did you put it in the right place?
Try downloading youtube-dl (https://youtube-dl.org/downloads/latest/youtube-dl.exe), put the cookies.txt in the same folder and run in command line "youtube-dl.exe SOME_YANDEX_TRACK_URL --cookies cookies.txt".
добрый день, при воспроизведении Yandex.Музыки вываливается ошибка. cookies.txt - не помогает. сессию не прирывал. Прикладываю скрины.
v2.0.1 - https://github.com/jaryn-kubik/AimpYouTubeDL/releases/tag/2.0.1- fixed some memory leaks- more workarounds for youtube webp thumbnailsWhat sites were you trying it with? Youtube or something else?Problems on first run could be because it downloads/updates the youtube-dl.exe, I should probably run that on separate thread and display someting if you try adding/playing url while it's downloading.I've been trying clicking on stuff aggressively and fixed some memory leaks/access violations the AIMP debug version was reporting in 2.0.1 and can't really reproduce any crashes anymore.
