It would be nice if the next version had these features!1. Visualization of the waveform of the track in execution and of the following trace, of large dimensions as well as possibility of zooming of the waveform;2. Ability to set the starting point of reproduction and the end point of reproduction of each track and saving of the mentioned settings;3. Possibility of previewing on secondary exit, for each track.
its easy, you can create a skin for your taste and have it!
Sorry, but I'm not a programmer... the message is for the programmers ...
1. It can be done via creating custom skin (or editing of standard). Use the SkinEditor tool to do that2. I plan to make possible to visualize the A-B-repeat ranges, but not to store / re-use it. This thing looks good for DJ studio, not for player, I think.
to make a skin you dont need to be a developer but someone with knowlege
Thanks, I'll try to do it ...
