Been using this for about a week now, and has been working great! But the latest version makes it look like when i click on my name that im offline and not listening to anything, while the normal name tag says online and playing AIMP. Here's a screenshot on what's happening: https://i.imgur.com/NoAxxQh.pngOthers say they can see me normally online and can see what song im playing, so i guess its something with the plugin that is messing up for only myself? I have tried re-enabling the plugin, restarted both discord and AIMP, restarted PC but nothing helps.Would be great if you could look into this. Other than that, great plugin. Thank you for the work you're putting into this!
It's update of Discord. I noticed it today with all the games.
Ah okay, i see. Do you think Discord will fix it from their side?
I hope that will fixed
