привет будет версия с белой полосой размытия?
1 - In the first part in this place to place a button to open / close the playlist, the presence of a button to quickly open and close the playlist is essential.
...Also, the buttons and the name of the song, the musician should all be brought down a bit so that more space can be seen from the album cover and image.2 - In the second part, the font related to the name of the song should be smaller and the distance between the name of the song and the musician should be half what it is now. Also, both the part related to the name and the composer of the song should be moved to a lower place to determine more space from the cover and the image of the song.
3 - The color of the line under the active tab should be a little darker.
4 - The distance of the texts to the left edge is very large and should be reduced and the texts should be closer to the edge, in fact, the distance between the text and the left edge should be reduced by half the current value. The font for the song name in the playlist should be slightly larger.
1- In the first part, the distance between the texts should be reduced and in fact the distance between the lines should be reduced to half of this value. The circular symbol next to the texts should become a solid, small and simple circle and become smaller. The frame and in fact the border around the frame has a light color and should be darker, the color of the border or frame should be dark.3 - The indentation distance from the left should be reduced and the texts should be closer to the left edge. This distance can be reduced to half this amount.
1- Make the font related to the album list bigger, use a simpler and smaller icon. Make the text color lighter....4 - The icon and the symbol corresponding to the down arrow become smaller. In this case, the flash looks a bit large and inconsistent.
2 - In the second part, all three options are visible and in fact the box is enlarged and the scroll mode disappears, all three options and the part without scrolling are visible, scrolling is not necessary and disappears....6- The width of the playlist section should be larger (about 1 and a half times) and the white line under the active tab should be darker. And have opening and closing.
3 - If possible, delete the genre and year of release of the album so that only the name of the album and the name of the composer remain. Makes the user interface more beautiful.
Chivo, thanks, I appreciate the feedback.
