For personal use, I want to change some icons, sizes and colors, I want to try different modes with different sizes, layouts and colors.
Привет, я пишу из перевода, потому что не знаю русского. Можете ли вы сделать эту тему на турецком языке для меня?e-mail мой адрес: mtkbbr.dyn66@gmail.comСпасибо заранее
I can't do that, since I don't know Turkish
Well then "Soot_English_3. 1.lng.if I translate this file that you gave as" txt " into Turkish...?
If you are confident you can make a good translation, sure.
I don't know how to send from here
Press "Reply", then click "Attachments and other options", select the file you want to send (you may have to rename it from .lng to .txt) and click "Post".
Thank you. I will include it in the next update.I will send you a private message if the translation needs to be updated in the future.
Hi, you'd better add a volume control button
And if you specify when the update will come
Hi, there's something. I get this error when I suddenly rewind the time.
