Thanks koelo for the 4.5 version and the cover art/viz switch coming back in a dpi-aware skin! Suggestion: as the large wave/seek bar does not appear for radio stations, add option to toggle that frame off and on, or to appear as a scrolling display for radio streams as with Bliss 4K. Keep up the good work!
Many thanks for the work! New 4.50+ default with white background is completely unusable, with any color settings it's very hard to see current track in the playlist. With dark background it's so much easier!Спасибо за скин )
Hey!I like your skin a lot. But could you upload a *.acs4proj file, I'd really like to make some changes.Thanks in advance!
Best Skin Ever!!Thank you very much for your work!You are awesome with good taste!
Здравствуйте,а как вернуть планировщик на главное окно ?
i specifically registered here to thank you for the excellent cover
Это самый лучший скин который я видел, очень удобный, хочу чтобы он был по умолчанию. Ещё раз, он очень классный.
