0 Members and 277 Guests are viewing this topic.
А где Analog Meter для aimp2
I notice that the Analog Meter takes its signal measurement after any EQ/DSP/VST effects have been applied, often resulting in very high readings. This can be seen by disabling/enabling the effects in real-time while the song is playing.Is there a possibility to add the option to pass the signal to the meter BEFORE the effects are applied, but keeping their effects active on the audible sound?
А плавность хода указателей чем регулируется, а то стрелки постоянно дрожат неестественно?
use plugins compatible with AIMP meter skins
Wow, someone supports our skins? Please, can you provide a link to these plugins?
The new 64-bit re-write of foo_vis_vumeter supports all of them (and BIN of course):https://www.foobar2000.org/components/view/foo_vis_vumeter/release/0.7.2MusicBee's VUMeter 2.5.1 also does:https://getmusicbee.com/addons/plugins/518/vumeter/
This would provide shared usage of a single skins folder
You can made a symbolic link to folder with skins. https://superuser.com/questions/1020821/how-can-i-create-a-symbolic-link-on-windows-10
