I guess this is a problem with their servers.Try to add these 2 lines to C:\Windows\System32\drivers\etc\hosts :74.208.224.110 minilyrics.com74.208.224.110 www.minilyrics.comYou need admin privileges to do that.
Mate, I follow all the steps and is not working. Sometimes the programa download a lyric, but it doesn't work like a .lrc file. I mean, there are never a sincronized lyrics.Please, if you solved the problem, let me know..Thanks!
Here I'll describe the steps for getting the MiniLyrics work on the launch of New AIMP. First of all - we know that AIMP4 does support WinAmp plugins - and we will use them.So steps:1) Create in AIMP subfolder "Plugins" new folder "gen_MiniLyrics"2) Copy from your MiniLyrics subfolder "Player-Plugins" the file "gen_MiniLyrics.dll" into the Folder you created in step 1)3) Open Notepad4) Write in it (without stars):***[MiniLyrics]***WorkingFolder=YourMiniLyricsFolder5) Save the file in folder you created in Step 1) as "MLPlugin.ini" (DO NOT SAVE IT AS *.TXT FILE!!!)NOTE: YourMiniLyricsFolder should be full directory (for example: WorkingFolder=E:\MUSIC\MiniLyrics\)
