Thank you! It helps to let reduce about 7-10% of CPU.
Good! +1
Ох как не хватает кнопки "Стоп"
It would be cool to be able to move the seek bar to the top position, because it is a long way for my mouse cursor to stop the track and then minimize AIMP.
Yeah, you are right, it will look strange then. Okay, it may stay how it is .The skin is perfect overall (just the blur feature and wave animation is taking so much CPU usage ).
Group header and first line have same color (and font) in playlist. Can it be changed?
Hold left mouse button on Pause (while playing) leads to "start" instead "stop".
