При смене скинов Текникс для АИМП4 начинает воспроизведение текущей песни с начала. Другие скины этого не делают, продолжая воспроизведение.
Нет возможности сменить "кассету", как в некоторых других скинах.
В "деке" светодиодный индикатор никогда не выходит в желтую и красную области, просто "упирается" в них. В скине для 3.6 такого не было.
I love the work you did on all these skins. I also love this Technics one. The only thing that I wish it had was a different tape deck. The deck used looks kinda pale compared to the amp and EQ. Would it be possible to use a different model of tape deck? Such as either these two?
translate.google:Do you really think that I will redraw the skin almost from scratch, just because you did not like this deck alone?What you offer, in terms of design, is not any better, especially the second one is a piece of plastic with regulators from the kitchen radio.
In RS-B905 I like the indicator. Maybe someday I'll make a skin out of it.
I found a video of the deck in play. Oh the memories...https://www.youtube.com/watch?v=YELcwIk4PJQ
To create a skin first of all you need high-quality photos with high resolution, strictly at right angles to the front panel and minimal geometric distortions.Such photos on the Internet are hard to find.
So do you use the high resolution photos to import into a skin template I take it or is it just using them as a reference to draw yourself?
Are your own these photos?
