How do you like it?fastpic СПАММ[/color].ru/]
Кстати в исходниках это исправлено, надо обновить обложку в каталоге
Done
Try to use it! Now scin hawe more options and new background. 24.02 update.Read more...Fixed some bugs.Added new mode, based on LPlayer AIO Skin (https://aimp.ru/forum/index.php?topic=41314.0):fastpic СПАММ[/color].ru/]You can enable this mode on settings pannel when used large cover: fastpic СПАММ[/color].ru/]you also can disable borders in this mode to better experience.26.02 update.Read more...Fixed some bugs.To header added button to disable playlist. So now you can make some like this:fastpic СПАММ[/color].ru/]Added "Lama" animation to top information bar:fastpic СПАММ[/color].ru/]27.02 update.Read more...Fixed some bugs.Optimized some buttons in options window.Added optional running line to header.To bottom playlist manager added "AutoHide" search field.P.S. Excuse me for using your scin without agreement.
Zero, can you post the .acs3proj file for the latest version? I'd like to modify the LP mode a bit. Thanks!
