Can you change by places of active/normal textures of tabs in "Options" container?And why settings of main window drops if cursor directs to the "Options" container?
2. Intended to prevent skin from becoming huge.
Very nice skin But when I located the album cover on the left or right, I can not attach Aimp to the left or right edge of the screen. Can you fix it? Thank you.
Updated the skin, need a moderator to update the catalog file. I can't modify.Included the source file. Changelog in first post.
man, it's the best skinplease make gray as in itunes or white and throw me an email mmiviee@gmail.com
