При установке плагина на AIMP v4.01 он отображается в списке
I installed AIMP 4.02 and tried out Current Track Info To File, but there is a problem. Your Addon reads Last Playback before AIMP has updated that field. AIMP waits until about the half way point in the audio file before updating Last Playback. You can see this happen in the main window of AIMP. Can you persuade the author of AIMP to update Last Playback immediately upon track play? Then Current Track Info To File would print the correct value of Last Playback to the file.
How can i save the current track info to file? is there a hotkey to save the current track info to a file?can i save more as one info to the file?
Thanks for the info - I didn't know about those settings. I'll try those.
Can the Player author change the player to update %LastPlayDate, %LastPlayTime, %PlayCountwith no offset to Minimum Threshold?
Скачать 3.5.3 (917 кб)Добавлено обновление строки с информацией после обновления информации в фонотеке.Исправлено чтение UTF-файла как ANSI при включённой опции сохранения в UTF.Обновлена эстонская локализация.
He says that it's impossible due to operating system message processing limitations.I'm looking for some workaround in the plugin.
2 MindExcursion:This version will update (not add new!) string (and re-save file) when library info is updated. Please try.
Скачать 3.5.4 (917 кб)Исправлено обновление информации о треке при остановленном воспроизведении.
