Hi there!Current Track Info To File v3.5.2 hangs on AIMP v4.00, build 1687 (18.01.2016).
show plugin settings
Hello! Using this plugin with Windows XP SP3 and AIMP v4.00, build 1687 with couple of other plugins, no troubles at all.Please show your settings.
If I localize Current Track Info To File to Español (Argentina) language and send it to you, would you mind to add it with the next release, please?
Всем привет. Подскажите, пожалуйста, можно как-то %replace() скобки?
Here it is!
In a future release would it be possible for you to add %PlayDate and %PlayTime to the Template options?
I would like %PlayDate and %PlayTime to print the date and time the track was played. Hopefully that won't be too much work.
