Total Members Voted: 29
Верните мне Remote control! Приложение очень, очень ограничено в функционале. На практике, это только пауза/пуск/предыдущий трек/следующий трек/перемотка и регулятор громкости. Мне не хватает( Но разработчику всё равно спасибо.
I am using the paid version of MonkeyMote (v. 1.7.2)
Right now only the foobar version supports browsing by folder, sorry. I may add this feature in the future for other players, including AIMP.As long as your music files are tagged properly, you should be able to find them, though.
If you're having trouble using MonkeyMote, wish to report a bug or suggest a new feature, please email Support (support@monkeymote.com) or send a message via Facebook. Support requests should include a detailed error description and mention which media player and device you are using.
I am using MonkeyMote v1.2.2 on my PC with MonkeyMote v1.7.7 (paid version on Android phone) from the Google App Store.The problem is that the EQ on Aimp in Windows, & the EQ in the Remote have different frequency channels, resulting in a mismatch of most sliders (eg. moving the 4k slider in the Remote moves the 2k slider in Aimp).Also, any saved Profiles do apply correctly in Aimp, but do not display correctly in the Remote.Also (& most annoyingly) any manual movement of any slider (even the horizontal "Preamp" slider itself) results in the actual Preamp slider in Aimp going to 0, with no way at all to move it back where you want it, even using a profile leaves it at 0.Please Advise!
Thanks for reporting this. Please update both the AIMP 5 plugin and the Android app and let me know if that fixes the problems.
On AIMP5 Windows, MonkeyMote says that there's a new update 1.2.3 but even if i go to https://www.monkeymote.com/download and download "AIMP 5 package", it keep saying there's a new version (1.2.3)
Plugin download has been updated now, sorry.
