If you have a huge library
Okay, thank you. I have removed the folder Aimp_DiskCover from \Aimp\Plugins.[Then installed the 32 bit version with this install option:But I cannot find it.
Open a profile folder (under the settings menu).Close AIMP.Open AIMP.ini in a profile folder.Clear [Plugins] AND [Plugins.CachedInfo] sections. Save file.Run AIMP.
P.S. You can reinstall AIMP to x64 without replace (move/remove) settings.
But some plugins only x32, so need check your plugins.
remove the "cover" expression from the plugins search box to be sure you're seeing everything. Is it in the main listing now?
If not delete its folder again. Are you using the "-x32" zip from Github, or "aimp_DiskCover.zip" file from the AIMP website?
Yes with the problems you describe you SHOULD benefit from using the 64-bit AIMP. You're right about your settings probably being "complex", or else the best route is a new-from-scratch one.
I guess that involves downloading the 64-bit installer, and telling it put the Portable version into the same folder you use now.
As he said though, any 32-bit "3rd-party" plugins would need to be deleted and reinstalled in their 64-bit formats--if those formats exist, including DiskCover Plugin.
and make a whole new 64-bit portable install in a DIFFERENT folder than the 32-bit. Then you can use it fresh and gradually move your settings, playlists, etc. from the 32-bit one over to it at your own pace.
You do a lot of things and ask a lot of questions.
