using System;using System.Drawing;namespace AIMP_SDK.Units{ public class Units { public static readonly int WM_USER = 0x0400; public static readonly int AIMP_PLUGIN_NAME = 1; public static readonly int AIMP_PLUGIN_INFO = 2; public static readonly int AIMP_PLUGIN_AUTHOR = 3; public static readonly int AIMP_PLUGIN_EXTS = 4; // ============================================================================== // R E M O T E I N F O // ============================================================================== public static readonly string AIMP2_RemoteClass = "AIMP2_RemoteInfo"; public static readonly int AIMP2_RemoteFileSize = 2048; public static readonly object WM_AIMP_COMMAND = WM_USER + 0x75; // WParam = One of Command, LPARAM - Parameter // see parameters for AIMP_Status_Get/AIMP_Status_Set public static readonly int WM_AIMP_STATUS_GET = 1; public static readonly int WM_AIMP_STATUS_SET = 2; // HiWord of LParam - Command, LoWord of LParam - Parameter public static readonly int WM_AIMP_CALLFUNC = 3; // LPARAM - Func ID (see below Func ID for Addons) public static readonly int WM_AIMP_GET_VERSION = 4; public static readonly int WM_AIMP_STATUS_CHANGE = 5; public static readonly object WM_LANG = WM_USER + 101; // CallBack types public static readonly int AIMP_STATUS_CHANGE = 1; public static readonly int AIMP_PLAY_FILE = 2; public static readonly int AIMP_INFO_UPDATE = 5; // Update Info for current track public static readonly int AIMP_PLAYER_STATE = 11; // Play/Pause/Stop public static readonly int AIMP_EFFECT_CHANGED = 12; // Balance, Speed, Tempo, Pitch, Flanger and etc. public static readonly int AIMP_EQ_CHANGED = 13; // Sliders changed public static readonly int AIMP_TRACK_POS_CHANGED = 14; // AIMP_Status_Set / AIMP_Status_Get public static readonly int AIMP_STS_VOLUME = 1; public static readonly int AIMP_STS_BALANCE = 2; public static readonly int AIMP_STS_SPEED = 3; public static readonly int AIMP_STS_Player = 4; public static readonly int AIMP_STS_MUTE = 5; public static readonly int AIMP_STS_REVERB = 6; public static readonly int AIMP_STS_ECHO = 7; public static readonly int AIMP_STS_CHORUS = 8; public static readonly int AIMP_STS_Flanger = 9; public static readonly int AIMP_STS_EQ_STS = 10; public static readonly int AIMP_STS_EQ_SLDR01 = 11; public static readonly int AIMP_STS_EQ_SLDR02 = 12; public static readonly int AIMP_STS_EQ_SLDR03 = 13; public static readonly int AIMP_STS_EQ_SLDR04 = 14; public static readonly int AIMP_STS_EQ_SLDR05 = 15; public static readonly int AIMP_STS_EQ_SLDR06 = 16; public static readonly int AIMP_STS_EQ_SLDR07 = 17; public static readonly int AIMP_STS_EQ_SLDR08 = 18; public static readonly int AIMP_STS_EQ_SLDR09 = 19; public static readonly int AIMP_STS_EQ_SLDR10 = 20; public static readonly int AIMP_STS_EQ_SLDR11 = 21; public static readonly int AIMP_STS_EQ_SLDR12 = 22; public static readonly int AIMP_STS_EQ_SLDR13 = 23; public static readonly int AIMP_STS_EQ_SLDR14 = 24; public static readonly int AIMP_STS_EQ_SLDR15 = 25; public static readonly int AIMP_STS_EQ_SLDR16 = 26; public static readonly int AIMP_STS_EQ_SLDR17 = 27; public static readonly int AIMP_STS_EQ_SLDR18 = 28; public static readonly int AIMP_STS_REPEAT = 29; public static readonly int AIMP_STS_ON_STOP = 30; public static readonly int AIMP_STS_POS = 31; public static readonly int AIMP_STS_LENGTH = 32; public static readonly int AIMP_STS_REPEATPLS = 33; public static readonly int AIMP_STS_REP_PLS_1 = 34; public static readonly int AIMP_STS_KBPS = 35; public static readonly int AIMP_STS_KHZ = 36; public static readonly int AIMP_STS_MODE = 37; public static readonly int AIMP_STS_RADIO = 38; public static readonly int AIMP_STS_STREAM_TYPE = 39; // Music / CDA / Radio public static readonly int AIMP_STS_TIMER = 40; // Reverse / Normal public static readonly int AIMP_STS_SHUFFLE = 41; public static readonly int AIMP_STS_MAIN_HWND = 42; public static readonly int AIMP_STS_TC_HWND = 43; public static readonly int AIMP_STS_APP_HWND = 44; public static readonly int AIMP_STS_PL_HWND = 45; public static readonly int AIMP_STS_EQ_HWND = 46; public static readonly int AIMP_STS_TRAY = 47; // Support Exts Flags public static readonly int AIMP_PLS_EXTS = 1; public static readonly int AIMP_AUDIO_EXTS = 2; // Menu IDs public static readonly int AIMP_MAIN_MENU_OPN = 0; public static readonly int AIMP_MAIN_MENU_UTILS = 1; public static readonly int AIMP_MAIN_MENU_FNC = 2; public static readonly int AIMP_MAIN_MENU_CFG = 3; public static readonly int AIMP_UTILS_MENU = 4; public static readonly int AIMP_PLS_MENU_ADD = 5; public static readonly int AIMP_PLS_MENU_JUMP = 6; public static readonly int AIMP_PLS_MENU_FNC = 7; public static readonly int AIMP_PLS_MENU_SEND = 8; public static readonly int AIMP_PLS_MENU_DEL = 9; public static readonly int AIMP_ADD_MENU = 10; public static readonly int AIMP_DEL_MENU = 11; public static readonly int AIMP_FND_MENU = 12; public static readonly int AIMP_SRT_MENU = 13; public static readonly int AIMP_MSC_MENU = 14; public static readonly int AIMP_PLS_MENU = 15; public static readonly int AIMP_TRAY_UTILS = 16; public static readonly int AIMP_TRAY = 17; public static readonly int AIMP_EQ_LIB = 18; // AIMP_CallFunction public static readonly int AIMP_OPEN_FILES = 0; public static readonly int AIMP_OPEN_DIR = 1; public static readonly int AIMP_ABOUT = 2; public static readonly int AIMP_SLEEP_TIMER = 3; public static readonly int AIMP_UTILS_AC = 4; public static readonly int AIMP_UTILS_SR = 5; public static readonly int AIMP_UTILS_TE = 6; public static readonly int AIMP_UTILS_CDB = 7; public static readonly int AIMP_OPTIONS = 8; public static readonly int AIMP_PLUGINS = 9; public static readonly int AIMP_QUIT = 10; public static readonly int AIMP_NEXT_VIS = 11; public static readonly int AIMP_PREV_VIS = 12; public static readonly int AIMP_EQ_ANALOG = 13; public static readonly int AIMP_TO_TRAY = 14; public static readonly int AIMP_PLAY = 15; public static readonly int AIMP_PAUSE = 16; public static readonly int AIMP_STOP = 17; public static readonly int AIMP_NEXT = 18; public static readonly int AIMP_PREV = 19; public static readonly int AIMP_ADD_FILES = 20; public static readonly int AIMP_ADD_DIR = 21; public static readonly int AIMP_ADD_PLS = 22; public static readonly int AIMP_ADD_URL = 23; public static readonly int AIMP_DEL_FILES = 24; public static readonly int AIMP_DEL_BAD = 25; public static readonly int AIMP_DEL_FROMHDD = 26; public static readonly int AIMP_DEL_OFF = 27; public static readonly int AIMP_DEL_OFF_HDD = 28; public static readonly int AIMP_RESCAN_PLS = 29; public static readonly int AIMP_SHOW_CURFILE = 30; public static readonly int AIMP_SORT_INVERT = 31; public static readonly int AIMP_SORT_RANDOM = 32; public static readonly int AIMP_SORT_TITLE = 33; public static readonly int AIMP_SORT_ARTIST = 34; public static readonly int AIMP_SORT_FOLDER = 35; public static readonly int AIMP_SORT_LENGTH = 36; public static readonly int AIMP_SORT_RATING = 37; public static readonly int AIMP_SEARCH = 38; public static readonly int AIMP_OPEN_PLS = 39; public static readonly int AIMP_SAVE_PLS = 40; public static readonly int AIMP_PLAY_LAST = 41; public static readonly int AIMP_OFF_SELECTED = 42; public static readonly int AIMP_ON_SELECTED = 43; public static readonly int AIMP_ADD2BOOKMARK = 44; public static readonly int AIMP_EDITBOOKMARK = 45; // For AIMP_GetPath public static readonly int AIMP_CFG_DATA = 0; public static readonly int AIMP_CFG_PLS = 1; public static readonly int AIMP_CFG_LNG = 2; public static readonly int AIMP_CFG_SKINS = 3; public static readonly int AIMP_CFG_PLUGINS = 4; public static readonly int AIMP_CFG_ICONS = 5; public static readonly int AIMP_CFG_ML = 6; // For AIMP_QueryObject public static readonly int IAIMP2PlayerID = 0x0001; public static readonly int IAIMP2PlaylistManagerID = 0x0003; public static readonly int IAIMP2ExtendedID = 0x0004; // For AIMP_ObjectClass public static readonly int AIMP_EXT_LC_MESSAGE = 100; public static readonly int AIMP_EXT_ML_MESSAGE = 101; // Option Frame Position Flags public static readonly int AIMP_FRAME_POS_PLAY = 1; public static readonly int AIMP_FRAME_POS_PLAYLIST = 2; public static readonly int AIMP_FRAME_POS_PLAYER = 3; public static readonly int AIMP_FRAME_POS_TEMPLATE = 4; public static readonly int AIMP_FRAME_POS_SYSTEM = 5; public static readonly int AIMP_FRAME_POS_SKINS = 6; public static readonly int AIMP_FRAME_POS_LANGS = 7; // PluginFlags public static readonly int VIS_RQD_DATA_WAVE = 1; public static readonly int VIS_RQD_DATA_SPECTRUM = 2; public static readonly int VIS_RQD_NOT_SUSPEND = 4; } // end AIMP_SDK}
using System;using System.Drawing;using AIMP_SDK.Struct;namespace AIMP_SDK{ public interface IPLSStrings { bool AddFile(string FileName, TAIMP2FileInfo FileInfo); bool DelFile(int ID); string GetFileName(int ID); bool GetFileInfo(int ID, TAIMP2FileInfo AInfo); int GetFileObj(int ID); int GetCount(); } // end IPLSStrings // User option frame public interface IAIMP2OptionFrame { IntPtr FrameCreate(IntPtr AParent); object FrameData(); // reserved int FrameFlags(); // See FramePositionFlags string FrameName(); void FrameFree(IntPtr AWindow); void FrameLoadConfigNotify(); void FrameSaveConfigNotify(); } // end IAIMP2OptionFrame // See IAIMPPlayerID public interface IAIMP2Player { int Version(); bool PlayTrack(int ID, int ATrackIndex); void PlayOrResume(); void Pause(); void Stop(); void NextTrack(); void PrevTrack(); } // end IAIMP2Player // See IAIMP2PlaylistManagerID public interface IAIMP2PlaylistManager { int AIMP_PLS_CreateFromFile(string AFile, bool AActivate, bool AStartPlay); int AIMP_PLS_ID_ActiveGet(); bool AIMP_PLS_ID_ActiveSet(int ID); int AIMP_PLS_ID_PlayingGet(); int AIMP_PLS_ID_PlayingGetTrackIndex(int ID); int AIMP_PLS_NewEx(string AName, bool AActivate); bool AIMP_PLS_PlayFile(string AFileName, bool AFailIfNotExists); // Playlist Processing bool AIMP_PLS_DeleteByFilter(int ID, object AFilterProc, int AUserData); bool AIMP_PLS_SortByFilter(int ID, object AFilterProc, int AUserData); // Entries bool AIMP_PLS_Entry_Delete(int ID, int AEntryIndex); bool AIMP_PLS_Entry_DeleteAll(int ID); bool AIMP_PLS_Entry_FileNameGet(int ID, int AEntryIndex, string PBuf, int ABufLen); bool AIMP_PLS_Entry_FileNameSet(int ID, int AEntryIndex, string PBuf); int AIMP_PLS_Entry_FocusedGet(int ID); bool AIMP_PLS_Entry_FocusedSet(int ID, int AEntryIndex); bool AIMP_PLS_Entry_InfoGet(int ID, int AEntryIndex, TAIMP2FileInfo PFileInfo); bool AIMP_PLS_Entry_InfoSet(int ID, int AEntryIndex, TAIMP2FileInfo PFileInfo); bool AIMP_PLS_Entry_PlayingSwitchGet(int ID, int AEntryIndex); bool AIMP_PLS_Entry_PlayingSwitchSet(int ID, int AEntryIndex, bool ASwitch); bool AIMP_PLS_Entry_ReloadInfo(int ID, int AEntryIndex); // Load/Save Playlists bool AIMP_PM_DestroyStream(int AHandle); int AIMP_PM_ReadItem(int AHandle, TAIMP2FileInfo PItem); int AIMP_PM_ReadStream(string AFileName, ref int Count); int AIMP_PM_SaveStream(string AFileName); int AIMP_PM_WriteItem(int AHandle, TAIMP2FileInfo PItem); // added in 2.50 B295 bool AIMP_PLS_ID_PlayingSetTrackIndex(int ID, int AEntryIndex); } // end IAIMP2PlaylistManager // See IAIMP2ExtendedID public interface IAIMP2Extended { int AIMP_GetPath(int ID, string ABuffer, int ACount); bool AIMP_ObjectClass(int ID, object AData, bool ARegister); // User Option Dialogs int AIMP_Options_FrameAdd(IAIMP2OptionFrame AFrame); int AIMP_Options_FrameRemove(IAIMP2OptionFrame AFrame); int AIMP_Options_ModifiedChanged(IAIMP2OptionFrame AFrame); } // end IAIMP2Extended public interface IAIMP2Controller { bool IsUnicodeVersion(); // Must be True CallBack bool AIMP_CallBack_Set(int dwCBType, object Proc, int User); bool AIMP_CallBack_Remove(int dwCBType, object Proc); // Status int AIMP_Status_Get(int StatusType); bool AIMP_Status_Set(int StatusType, int Value); // Playlist bool AIMP_PLS_Clear(int ID); bool AIMP_PLS_Delete(int ID); int AIMP_PLS_New(string Name); bool AIMP_PLS_Info(int Index, out TPLSInfo PLSInfo); ushort AIMP_PLS_Count(); bool AIMP_PLS_GetFiles(int ID, out IPLSStrings Strings); bool AIMP_PLS_GetSelFiles(int ID, out IPLSStrings Strings); bool AIMP_PLS_AddFiles(int ID, IPLSStrings Strings); bool AIMP_PLS_SetPLS(int ID); // System bool AIMP_NewStrings(out IPLSStrings Strings); bool AIMP_GetCurrentTrack(TAIMP2FileInfo AInfo); bool AIMP_QueryInfo(string Filename, TAIMP2FileInfo AInfo); int AIMP_GetSystemVersion(); bool AIMP_CallFunction(int FuncID); int AIMP_GetLanguage(string Str, int ACount); int AIMP_GetCfgPath(string Str, int ACount); int AIMP_GetSupportExts(int Flags, string Str, int BufSize); // Menu object AIMP_Menu_CreateEx(object Parent, TAIMPMenuInfo MenuInfo); object AIMP_Menu_Create(int MenuID, TAIMPMenuInfo MenuInfo); bool AIMP_Menu_Update(object Handle, TAIMPMenuInfo MenuInfo); bool AIMP_Menu_Remove(object Handle); // extantion bool AIMP_QueryObject(int ObjectID, ref object Obj); } // end IAIMP2Controller public interface IAIMP2InputStream { bool GetPositions(ref long ALength, ref long APosition); bool GetStreamInfo(TInputInfo AInputInfo); long SetPosition(long APosition); bool ReadData(object ABuffer, ref int ALength); } // end IAIMP2InputStream public interface IAIMP2InputPlugin { string AuthorName(); string PluginName(); string PluginSupportExts(); bool GetFileInfo(string AFile, TAIMP2FileInfo ATags); bool IsOurFile(string AFile); IAIMP2InputStream StreamCreate(string AFile, TAIMP2FileInfo ATags); void ConfigWindow(IntPtr AParent); void Deinitialize(); void Initialize(IAIMP2Controller AIMPClassic); } // end IAIMP2InputPlugin public interface IAIMP2VisualPlugin { string AuthorName(); string PluginName(); string PluginInfo(); int PluginFlags(); bool Initialize(); void Deinitialize(); void DisplayClick(int X, int Y); //void DisplayRender(HDC DC, TVisualData AData); //void DisplayResize(int AWidth, int AHeight); } // end IAIMP2VisualPlugin}
using System;using System.Drawing;using System.Runtime.InteropServices;namespace AIMP_SDK.Struct{ [StructLayout(LayoutKind.Sequential, CharSet = CharSet.Unicode, Pack = 4)] public struct TAIMP2FileInfo { public int cbSizeOf; // public bool nActive; public int nBitRate; public int nChannels; public int nDuration; public long nFileSize; public int nRating; public int nSampleRate; public int nTrackID; // public int nAlbumLen; public int nArtistLen; public int nDateLen; public int nFileNameLen; public int nGenreLen; public int nTitleLen; // public string sAlbum; public string sArtist; public string sDate; public string sFileName; public string sGenre; public string sTitle; } // end TAIMP2FileInfo [StructLayout(LayoutKind.Sequential, CharSet = CharSet.Unicode, Pack = 4)] public unsafe struct TPLSInfo { public string PLSName; public int FileCount; public int PLSDuration; public long PLSSize; public int PlaylistID; } // end TPLSInfo [StructLayout(LayoutKind.Sequential, CharSet = CharSet.Unicode, Pack = 4)] public unsafe struct TAIMPMenuInfo { public bool CheckBox; public bool RadioItem; public bool Checked; public bool Enabled; public object Proc; // TAIMPMenuProc; public Bitmap Bitmap; // 0 - no bmp public string Caption; public int User; } // end TAIMPMenuInfo [StructLayout(LayoutKind.Sequential, CharSet = CharSet.Unicode, Pack = 4)] public unsafe struct TAIMPAddonHeader { public byte Version; public int DllInstance; public object GetPlgName; //Proc; public object GetAuthor; //Proc; public object Init; //Proc; public object Config; //Proc; public object Free; //Proc; } // end TAIMPAddonHeader [StructLayout(LayoutKind.Sequential, CharSet = CharSet.Unicode, Pack = 4)] public unsafe struct TInputInfo { public int SampleRate; public int Bits; public int Channels; } // end TInputInfo [StructLayout(LayoutKind.Sequential, CharSet = CharSet.Unicode, Pack = 4)] public unsafe struct TVisualData { public int LevelR; public int LevelL; public byte[,] Spectrum; public sbyte[,] WaveForm; } // end TVisualData}
public object Proc; <-- public object GetPlgName; <--public object GetAuthor; <--public object Init; <--public object Config; <--public object Free; <--
public class Units
public enum PluginInfo { Name = 1, Info, Author, Exts);
[StructLayout(LayoutKind.Sequential, CharSet = CharSet.Unicode, Pack = 1)] public struct TAIMP2FileInfo
Особо проблемы возникают со структурами TAIMPMenuInfo и TAIMPAddonHeader
Keannad... Первое можно сделать сторонними утилитами, добавляющими таблицу экспорта. ...
Для этого автору нужно добавить поддержку COM в интерфейсы SDK (сейчас они не полноценные). В принципе, это не сложно, но нужно время и желание
Я был бы не против писать плагины для AIMPa на шарпе...Но хотелось бы поодержки таких плагинов самим AIMP'ом.. ))
Извините, не понимаю как поддержка COM может быть более полноценной и как это влияет на C#
разрешить управлять загрузкой плагинов другому плагину
идея написать универсальный врапер, который бы позволял писать плагины на любом языке (включая JavaScript, Python и Perl)
А сейчас разве это запрещено?
ComVisible(false), если понимаете, о чём я.А сейчас разве это запрещено?
Ну написать свой загрузчик в виде плагина, со своей логикой загрузки и управления других плагов.
