Critical Feedback on Library Sorting: I've encountered a significant usability issue in the library view, particularly when using detailed list views with album thumbnails. The current sorting logic seems to struggle with hierarchical metadata. There is a conflict when sorting by "Year" versus sorting by "Track Number," which is exacerbated for multi-disc albums.When sorting the main library by Year to view my music chronologically, the internal order of tracks within an album is often lost, destroying the intended listening sequence.Conversely, sorting by Track Number to preserve album order completely disrupts the chronological year-based view of the library.The desired behavior would be a primary and secondary sorting mechanism that respects the album structure. For example: Primary sort = Year -> Secondary sort = Album Artist/Album -> Tertiary sort = Disc Number -> Quaternary sort = Track Number. This would present a library sorted by year, where each album's tracks are kept in their correct order.
In the Music Library and Tag Editor you can sort the table by multiple columns: to do this just click on column with pressed CTRL key.
