DennoN
a Windows 10 bug - windows 10 is updated, just downloaded installed latest AIMP
Topic: a Windows 10 bug - windows 10 is updated, just downloaded installed latest AIMP (Read 3100 times)
January 06, 2025, 01:26:39 »
1Steven
Продвинутый
I now have 2 aimp installations, 1 under Program Files and 1 not. Symptom is Microsoft Media Player skin is displayed instead of AIMP skin (Violet) on running any shortcut to the AIMP installation in Program Files\AIMP.
I made a new shortcut to the one not under Program Files and it showed my AIMP skin. I did something inside AIMP and it showed the Media Player skin and changed the shortcut destination folder and "start in" box in the file properties tab in File Explore. Older shortcuts pointing to Program Files\AIMP show media player skin. Very strange. I am planning to 7zip up the two AIMP folders, delete and reinstall new one again. I have a lot of skins and plugins and playlists. Seems like a lot of trouble but will be worth it to have a proper installation of AIMP. I think I did a Windows installation of the newest AIMP.
Also, I now have only one playlist with all files from different folders in it.
I am willing to follow your directions first to figure out what happened. I will try not to make the same mistake twice.
Re: a Windows 10 bug - windows 10 is updated, just downloaded installed latest AIMP
January 06, 2025, 01:51:29 »
Супермен
Карма: +446/-73
Your explanations sound strange. Bad translator or incorrect terms? Take screenshots (full screen) of what looks wrong. If there are many, record a video or post an archive with a series of images.
Error reports are usually formatted according to the rules. Use a translator if you don't know the language of the message.
https://www.aimp.ru/forum/index.php?topic=5451.0
January 06, 2025, 02:14:44 »
1Steven
Продвинутый
A screen shot attached. (I think I got it capture.png) What do you think? See how the AIMP help window is blank? You can see part of the Media Player skin.
5.30.2563 64-bit, Module: AIMP.exe file displaying Media Player default skin
January 06, 2025, 03:06:11 »
1Steven
Продвинутый
ATTENTION! If you have received a remark from a moderator with a request to REFORMAT THE TOPIC according to the rules of the section, then after reformatting WRITE ANY MESSAGE in your topic (for example, "did" "reformatted" "up" etc.). This way you report that you have fulfilled the requirements and again draw attention to your topic with the problem. Otherwise, the topic may get lost.
IGNORANCE DOES NOT RELEASE FROM LIABILITY!
First, carefully read the topic: [IMPORTANT] Forum rules (must read)
BASIC RULES FOR THIS SECTION:
1. Preparation for writing a message :
1.1 Before creating a topic, update the player to the CURRENT VERSION , and check the reproducibility of the error on it, because it could have already been fixed, even if it was not mentioned in the log of fixed errors.
1.2 Also use SEARCH . It is possible that a similar topic already exists.
> 5.30.2563 64-bit, Portable (01.08.2024)
2. Topic design :
2.1 Each error must have a separate topic.
2.2 The topic title must be in the form: [Build number][Bit depth] Module: the essence of the question.
- "Bit depth" - x64 or x32
- "Module" is AIMP / ATE / Installer, roughly speaking, an exe-file or a plugin
Example: [810][x64] ATE: Changing tags in mp3 does not work.
> 5.30.2563 64-bit, Portable (01.08.2024) AIMP.exe program
> Module: AIMP.exe file Windows 10: AIMP is displaying Microsoft Media Player default skin
2.3 The topic title should reflect the main idea, the essence of the topic (topics with names like "glitch", "small problem" and other meaningless ones can be deleted).
2.4 Prefix before the build number (put only by the developer or moderator!):
- missing - the developer has not viewed this topic yet
- [ x ] - fixed
- [ ? ] - the problem could not be repeated
- [ + ] - resolved, it is not possible to correct the comment, the described behavior is not an error
- [ - ] - incorrectly formatted topic
2.5 If you want to leave a comment on the player, then put the prefix [З] before the prefix with the build number.
3. Topic content :
> AIMP is displaying a Microsoft Media Player skin when run. I have by accident 2 installations of AIMP, 1 in Program Files\AIMP and one somewhere else. Attachment shows AIMP help (blank) with AIMP running with Media Player skin partially viewable.
3.1 Try to describe the problem in as much detail as possible. If you cannot explain it in words, take a screenshot or record a video from the monitor screen (I recommend using UVScreenCamera ) and attach it to the message.
List of alternative screen recording programs (from remontka.pro)
3.2 If you have problems with a file, radio, etc., then provide a link to the file itself. If you get a bug report window, then post the bug report file ( where can I find it? ).
> Attachment "capture.PNG"
3.3 In your message, specify the version of your OS (operating system) in detail (for example, Win XP SP2 RUS or Win Vista 64 SP1 ENG or Win 10 Pro build 1903 RUS).
> Don't know where to find Windows 10 version, updated as of 1/5/2025
4. Release of a new build :
4.1 When a new build is released, check the reproducibility of old errors:
- If the error is fixed and you no longer have it, then report it.
- Otherwise, update the topic title, remove the [ x ] prefix and report that the error is not fixed.
« Last Edit: March 09, 2023, 09:55:38 by Artem »
Report to moderator Logged
Re: my bug report - more information Bug Resolved
January 06, 2025, 04:03:10 »
1Steven
Продвинутый
I have figured out that the Media Player skin is just an AIMP skin I downloaded to help with running visualizations earlier. It is not the real Media Player skin, just a skin for AIMP that looks like it, "WMP10 Full Mode". My bug is resolved.
I think I will need to uninstall both of my installations of AIMP and re-install. User error.
DennoN
