AIMP for PC > Ошибки и замечания / Bugs
[?] [2563] A lot of the issues in Windows 11 24H2
(1/10) > >>
mandoju:
Hello,
I used AIMP for Windows, version AIMP v5.30.2563 on my  DELL XPS 8700 Intel  Core I7 4790 Desktop with 16GB of RAM on Windows 11 23H2, everything works perfectly. I updated to Windows 11 24H2, AIMP are horrible! The Tascan 32 and another SKINs  doesn't work anymore, the VU´s pointers don't move still stoped, and doesn't respond to controls, and it gives some memory error! I did a clean install of Windows 24H2, same problem, it only  works  well  when I start AIMP as administrator user, this issues  will stop. Any solutions?
Jorge, Rio de Janeiro Brazil.
Artem:
Please, try to reproduce the issue on debug build: https://disk.yandex.ru/d/TkQ1BX_gjbISQw
sveakul:
I did an in-place upgrade to Windows 11 24H2 x64 from 23H2 via the Microsoft ISO.  This is with a Dell XPS 8960 with 32MB RAM and the Intel I7-13700.
Before and after I am using AIMP 5.30.2563 x64, Portable.  I have encountered absolutely no negative effects or regressive behavior at all, it runs as smooth and stable as it did before, including meter plugins, etc.  I am using a slightly modified (e.g. text fonts) Charm 1.36 skin.
I run Windows as an Administrator user, no UAC.  I do not use "Run as administrator" with AIMP.
What this means I guess is that neither 24H2 nor AIMP 5.30.2563 are the problem.  Why don't you try a test install of the Portable in a folder not part of the Windows permissions hierachy, like c:\AIMP, and see if you have the same issues using a stock skin.  Be sure you have excluded the AIMP folder in Windows Defender, and check to be sure your AIMP "Sound Output" settings in Preferences haven't changed.
Artem:
--- Quote from: sveakul on December 14, 2024, 21:52:37 ---Why don't you try a test install of the Portable in a folder not part of the Windows permissions hierachy, like c:\AIMP, and see if you have the same issues using a stock skin
--- End quote ---
I am using Windows 10 and have no issues with portable installation. Unfortunately, I cannot test by myself on win11 24h2.
sveakul:
--- Quote from: Artem on December 15, 2024, 08:55:23 ---I am using Windows 10 and have no issues with portable installation. Unfortunately, I cannot test by myself on win11 24h2.
--- End quote ---
Can't you download the ISO from the third option here: https://www.microsoft.com/en-us/software-download/windows11
From what I read, Windows 10 CAN be directly updated to 11 24H2.  You may have to use Rufus 4.6 (https://rufus.ie/ru/); according to its change log, "Added a new setup.exe wrapper to bypass Windows 11 24H2 in-place upgrade restrictions."  I believe the ISO itself can also be downloaded via Rufus.
Navigation
Message Index
Next page
Go to full version
