Copy file info to clipboard not working in Tag editor. Nothing is copied. However it works with hot key on playlist.
I don't know why, but it doesn't work any more.
Shouldn't they be the same as set in main app for the same functions?
Ah ok, default works, but mine was %IF(%Artist,%Artist%IF(%Album, - %Title,%IFEqual(%Title,%FileName,, - %Title)),%IF(%Album,%FileName,%Title))I don't know why, but it doesn't work any more.I think it still works here:
In my case, all works fine.
в отсутствии автоподстановки имени файла в шаблон %Title
В общем случае на это затачиваться и не надо.
выдаёт разные строки в зависимости от места вызова
