new/changed files on the desktop are not reloaded (refreshed) in the smart playlist
When I restart AIMP it changes to some strange path (but reloading works):
Unfortunately, I does not reproduce the issue. What file system is used in system drive?
I've fixed that. Just now, you can enable absolute filenames in app settings.
I will observe if there is a problem with refreshing the playlist now and let you know
Data is only reloaded when the appropriate smart playlist is selected. When another one is selected, the data is not reloaded automatically.
This is not entirely true, the player loads playlists on demand. If playlist is not loaded, smart-rules are not active. This is correct behavior, because unloaded playlist cannot be used, but if you activate it (the playlist will load it content and synchronize according the settings). Do you have the "sync on startup" option is set to true?
What do you mean by "playlist load/loaded/unloaded"?
Right Mouse Button over Playlist --> Managing Playlists
When another one is selected, the data is not reloaded automatically.https://i.imgur.com/ociC9Og.gifv
Changing the case of the file name does not reload the data
Sure, because file names in Windows are not case-sensitive
