AIMP for Android > Ошибки и замечания / Bugs |
EQ Problems |
<< < (3/3) |
Chonga2520:
best version so far! very good resolution in the bass. i like this one :) Measurements: https://drive.google.com/drive/folders/1SfpWL1PAu1tZ_myi-mixRNj81gFT-BcA?usp=sharing |
Artem:
--- Quote from: Chonga2520 on June 13, 2024, 10:23:41 ---best version so far! very good resolution in the bass. i like this one :) Measurements: https://drive.google.com/drive/folders/1SfpWL1PAu1tZ_myi-mixRNj81gFT-BcA?usp=sharing --- End quote --- In this build, 8192 points are used for equalizer. I think, will be better to make it optional (for low-end devices) |
Artem:
Another build to try: https://disk.yandex.ru/d/vBPf6jazuiyqzw I've added the equalizer quality setting |
AKhod:
--- Quote from: Artem on June 18, 2024, 00:22:21 ---Another build to try: https://disk.yandex.ru/d/vBPf6jazuiyqzw I've added the equalizer quality setting --- End quote --- При включении эквалайзера имеется скачок/щелчок, чем качественней экв, тем громче. В "свет" пойдет? |
Navigation |
Message Index |
Previous page |
