Suggestions
[1347] Please increase priority of aimp notification
Topic: [1347] Please increase priority of aimp notification (Read 7461 times)
August 16, 2023, 16:48:39 »
m0d
Карма: +11/-0
Aimp notifications are always hidden behind other notifications.
It is probably because other apps are putting higher priorities.
All apps including Other music apps, like newpipe, are always shown before aimp.
I switched from aimp notification/kind to system, because aimp player controls were not showing when music is playing.
Now when playing controls are shown, but as soon as you pause it all other apps appear before aimp even though they are paused as well.
Re: [1347] Please increase priority of aimp notification
August 16, 2023, 18:13:35 »
Супермен
Карма: +3001/-65
Refer to app notification settings (app settings / integration / notifications)
August 17, 2023, 10:19:22 »
m0d
Карма: +11/-0
I did not see any way to increase priority:
All notifications are enabled.
It is just, if another app also uses audio, then that app shows before aimp.
If another app sends notification, it appears before aimp.
If two music apps are paused in background, the other apps always appear before aimp
August 17, 2023, 10:34:13 »
Супермен
Карма: +3001/-65
Click the "Playback" item to enter to it settings
Suggestions
