AIMP recognizes each of the songs with overlapping track numbers as the songs from the previous disc, and any additional track numbers beyond what were on the previous disc are not recognized and simply called "AudioTrack X". Is there a setting I am missing to prevent this issue? I tried inserting a different disc in between, to see if it was just a memory thing, but that did not address it
Sure, the player does not know whether this is the second disc or even a disc by another author. But you can specify output path and file name in converter settings
suppose I am a bit confused as it "knows" the original disc, and every disc in between, but cannot seem to recognize that the second unique disc in a set of two happens to be completely different than the first? Other programs did not behave this way when testing it out.
titled "AudioTrack XX" and I cannot change this inside program before starting the rip.
