Aimp for Android: wrong playback
Topic: Aimp for Android: wrong playback (Read 2374 times)
May 30, 2023, 11:49:24 »
sarroutbi
After latest Android update, sound is only playing in one channel and with a lot of distortion
Android version: 12.02
AIMP version: v.3.30
Regards
Re: Aimp for Android: wrong playback
May 30, 2023, 11:53:54 »
Супермен
Карма: +2892/-55
Try to switch between different output methods (app settings \ sound \ output)
May 31, 2023, 10:34:24 »
sarroutbi
Hello. Thanks for your quick response.
I had that set in "Auto", and changed to all the different options available:
- OpenSL
- AudioTrack
- AAudio
Result is always the same, distorted sound in only one channel.
Regards
May 31, 2023, 11:25:13 »
Супермен
Карма: +2892/-55
Quote from: sarroutbi on May 31, 2023, 10:34:24
Are you uses headset or device speaker? Is issue appears on other apps?
