AIMP for PC > Обработано / Processed
[x] [2425] Internet Radio, Pause button behavior
(1/4) > >>
James4:
First, thank you very much for the latest 5.11.2425 release.
Can you please allow the old behavior where the Pause button stops the radio stream?
Maybe add an option in Internet Radio>General Settings?
Reasons:
The several seconds of buffer resets automatically and the program return to be live, so it is no different than stopping.
I use a small multimedia controller where I have a volume knob, next/previous and play/pause buttons, is was very convenient to stop the stream with the pause button.
Thank you again.
Artem:
Artem:
Player doesn't download the data if paused. So, no difference between pause or stop in this case. But if playback is paused you will able to resume the playback
James4:
There is a difference between pause and stop, otherwise I would not waste your time.
There is a limited amount of seconds that is buffered somewhere (server?) and if the stream is paused for more than a that specific buffer time, the stream will drop and restart like it was stopped.
Please test by downloading AAC file (Soma.FM):
https://somafm.com/u80s/
Pause for 3 minutes, then un-pause and listen.
After a few seconds the stream will drop and restart form 'live' point.
Maybe Soma.FM cuts the buffer when they change songs?  ???
Artem:
--- Quote from: James4 on March 28, 2023, 18:50:38 ---After a few seconds the stream will drop and restart form 'live' point
--- End quote ---
So, is it main issue of this behavior?
Navigation
Message Index
Next page
Go to full version
