Download from the site and update manually.After that, check what the update module and the scrobbler log shows.
Check firewall / antivirus settings. Usually, unknown error (-1) means that api call was refused by protection software.
OS?
Quote from: Artem on February 16, 2023, 21:37:50Check firewall / antivirus settings. Usually, unknown error (-1) means that api call was refused by protection software.so i try to add libre.fm, it worked.. got to login pagelast.fm still same, can't even connectidk anymore man
so i try to add libre.fm, it worked.. got to login pagelast.fm still same, can't even connectidk anymore manYou didn't write the details of the actions performed. Please note that the player also has settings.If the check does not help, then check the availability of domains in the command line, in a browser without a VPN / proxy (except for the proxy in your organization):last.fm aimp.ru aimp.su
If the ping to the servers is lossless, then it remains only to try to update the system. It is possible that the system has old root certificates and does not check the security of sites with new certificates.
