both other options have the same effect: they stop after the file and the next file is selected.
Nope, that doesn't work for me at all (and hasn't worked for at least many versions before). "Stop playback" stops the file immediately, both other options have the same effect: they stop after the file and the next file is selected.
What reason to keep playback cursor on just played track? Yes, switched off the option is one possible solution for now
WinAMP does / can do this different
Is it have an option for that behavior?
There's an right-click-option on "stop" to have it stop after the current playing track without moving on
Yes, you are right (I've checked now), but I think that this behavior is not correct, because you need to unable to start playback of next track immediately in this case.
"Play" repeats last played song, aftwards it keeps playing the queue
If you need to repeat a song after a STOP, use REPEAT switch, then use "right-click Stop after playback".… Play and switch repeat off.If you don't want a messing with a "repeat option", use "Show current" hotkey then add it to queue [Q] (if clear), then "right-click Stop after playback"…
Current song playback --> right-click "stop after playback" --> stops after song, same song stays highlighted --> "Play" repeats last played song, aftwards it keeps playing the queue.
Silver bullet is make this behavior optional (switched off by default), because winamp's behavior doesn't seem quite right.
WinAMP's behaviour is just right! ;-)
No,I don't think so
