Опрос 2024
DennoN
[2411] AIMP: File modified column shows one hour earlier than the actual time
Topic: [2411] AIMP: File modified column shows one hour earlier than the actual time (Read 3121 times)
November 11, 2022, 07:03:49 »
bgeo25
I recently noticed a bug that happens to the "file modified" column in the AIMP library. It affects the ability to sort songs by file modified date/time.
When playing a song, its "file modified" column changes to one hour earlier than the actual modification time. The time continues to show incorrectly even after AIMP is reloaded. I've been able to repeat this with many songs, but here is a simple example of this issue:
In this case, AIMP should show a file modification time of 14:30:20.
Might this have something to do with daylight savings time?
Thanks for the help.
AIMP v5.10.2411, OS: Win 10 21H2
Re: [2411] AIMP: File modified column shows one hour earlier than the actual time
November 11, 2022, 08:57:13 »
Супермен
Карма: +2929/-56
AIMP always use system time, it does not take daylight saving into account
November 11, 2022, 09:31:36 »
bgeo25
Thanks, but the file modified date/time that AIMP is showing is incorrect (regardless of whether DST is taken into account). The file metadata says that the file was modified at 14:30, but AIMP shows 13:30. Is there a way to show the correct date and time in this column?
November 11, 2022, 10:25:50 »
Супермен
Карма: +2929/-56
Yep, I will try to implement that
DennoN
