Open the problematic playlists in notepad, look at the paths in the player by highlighting the track and pressing the F4 key.Similarly, look at the paths through the explorer or when adding files individually.Fix paths through notepad in old playlists.
Okay, an update: I tried the thing in Notepad with a find/replace to make the file paths correct, but AIMP still can't find the bulk of them. The file paths haven't updated in AIMP but they have in the m3us. =/ Deleting the playlist from AIMP also deletes it from the hard drive and I don't see a way to JUST remove the playlist from AIMP. So I'm backing up the m3u and trying to reimport it.Which godddd that's annoying.Edit: AIMP says it'll delete it from your hard drive but doesn't actually seem to?
