AIMP for Android v4.00
DennoN
[x] [2398] AIMP not filling screen when maximized on windows
Topic: [x] [2398] AIMP not filling screen when maximized on windows (Read 1755 times)
September 04, 2022, 04:51:10 »
Kessi11
Hi,
I just updated from v5.02 to the latest stable release (v5.03 Build 2398) on Windows 10 (Build 19044.1889). Since that, the player window does not fill the screen fully anymore when maximized. To clarify what I mean, I attached a screenshot, where you can see a blue border (which is my desktop background) around AIMP.
If other windows are behind, I see those instead. Worst of all, clicking in that border area is handled by the window in the background (e.g. accidentally closing it instead of closing AIMP, because AIMP's X does not extend all the way to the screen corner).
The problem seems to be limited to my secondary screen (1280x1024), it works fine on the main 4k monitor. Furthermore, it is independent of the skin in use.
When the AIMP window is not maximized (meaning, normal window you can drag around), I can try to manually fit it to the screen size. That's a bit of a pain, however.
I would be glad if you could look into this or point me to a solution if one is already known. Let me know if you need any more details.
Please excuse if this was reported/answered before, these forums are a bit hard to navigate for non-Russian speakers
Best regards,
Kai
Last Edit: September 04, 2022, 14:53:15 by Artem
Re: [2398] AIMP not filling screen when maximized on windows
September 04, 2022, 09:18:12 »
Супермен
Карма: +2871/-53
What ui scale factor is used in OS?
September 04, 2022, 11:12:59 »
Kessi11
My second monitor, on which the problem occurs, uses 100% scaling. The main monitor (4k, no problem) uses 175%.
Re: [x] [2398] AIMP not filling screen when maximized on windows
September 04, 2022, 15:09:50 »
Супермен
Карма: +2871/-53
Please try this build:
https://disk.yandex.ru/d/quxupoT-JFT4PQ
September 04, 2022, 21:01:57 »
Kessi11
That fixes it, thank you for investigating!
DennoN
