Προκρούστης™ (Procrustes): The Real-Time-Stretching TechnologyΣίλεια™ (Sylea): The Real-Time Audio Resampling TechnologyAt last! A high-quality at a wide-range (from -50% to +200%), real-time-stretch technology that does not require a Cray®, and works in real-time even on slow x86 CPUs down to 233 MHz [if the CPU lacks an SIMD instruction set (3DNow! and SSE), else the speed doubles!]. Its dedicated transient processing provides the crispest possible attacks. Combined with the lack of any "phasiness", echos or other audible artefacts in a wide range of ratios, it makes it ideal for any purpose where quality and speed are equally important. That’s Προκρούστης™!Σίλεια™ is a resampling technology that provides 100% mathematically correct resampling, thus ensuring the highest possible audio quality with the same wide range, real-time capabilities, and low CPU requirements as Προκρούστης™.FPU, 3DNow! and SSE versions, written in highly optimised 100% pure assembly code, which are selected either automatically according to the CPU or manually, are available together in .DLL or object code format, suitable for linking with any 32-bit code on any OS, with a reference and usage examples in both Assembly and C++ to get you started instantly.And these treasures don’t require you to rob a bank to license!
