DennoN
[?] [2370] Playlist stopping after each song
Topic: [?] [2370] Playlist stopping after each song (Read 2478 times)
June 19, 2022, 13:56:12 »
saitch76
AIMP is now stopping playing after each track in a playlist. I haven't changed any settings and jump to next track is enabled in settings.
Anyone know how to fix this before I go back to Clementine?
Last Edit: June 20, 2022, 21:19:58 by Artem
Re: Playlist stopping after each song. V 5.02 Build 2370
June 19, 2022, 20:22:01 »
Супермен
Карма: +2850/-50
Please, make sure that files in playlist are not unchecked
June 19, 2022, 20:37:53 »
saitch76
Thanks, but yes, they're all checked.
June 19, 2022, 21:06:37 »
Супермен
Карма: +2850/-50
Please, share a screenshot of Options \ Player \ Automatic window
June 19, 2022, 23:56:25 »
saitch76
Attached.
June 20, 2022, 11:02:59 »
saitch76
I managed to get playlists to play in sequence by deleting the cache AND disabling the default scheduler plugin. Neither worked individually but did together. Looks like a bug?
Thanks for your suggestions Artem.
June 20, 2022, 13:20:22 »
Супермен
Карма: +2850/-50
How Scheduler was setup?
June 20, 2022, 13:35:20 »
saitch76
I'd never used it. It was enabled by default but there was no schedule created. I unchecked it.
DennoN
