I will keep testing
when I return to the one with the bookmark (because it is created I think) this playback starts from zero
Are there skins that have bigger control buttons?
I listen a lot while driving, the phone is in the holder and I have to aim well to switch to the next song
I don't use Android auto, I play directly on my phone. UI scaling doesn't quite work, I've already tried it
In v3.30, I planing to improve UI for CarPC layout. That's why I asked you about CarPC.But, as I can see now, its not your case. CarPC layout is available for landscape orientation only. Anyway, if you want to test new UI let me know.
I'd love to see CarPC
