Import a PC Itunes playlist into AIMP on a Redmi Note 9
Topic: Import a PC Itunes playlist into AIMP on a Redmi Note 9 (Read 1306 times)
November 25, 2021, 15:32:38 »
RichV
Hi, it took me a long time to figure this out so I hope this may help someone else
To Import a PC Itunes playlist into AIMP on a Redmi Note 9 do the following:
Export the Playlist from Itunes as M3U and Edit the exported Playlist in Notepad
Remove all Path information by issuing the replace all function, for example
C:\...\...\...\...\...\Billy Ocean\Love Is For Ever\01 Love Really Hurts Without You.mp3
Where ... is the path to the song folder. Issue a 'Replace all' command in Notepad to remove the path information.
I.e. Replace C:\...\...\...\...\...\ and leave the 'Replace With' blank. In this example the result would be:
Transfer the modified Playlist to your Music Folder on your Redmi and use the 'Import Playlist' function
to import the Playlist.
Last Edit: November 25, 2021, 15:47:57 by Soolo
