This playlist refers to an HLS stream. What version of the player is on the other computer?
On one computer works the other does not.-I believe it is the lack of some plugin, I just couldn't find which one it is. Both are the same OS.
Judging by the screenshot, do you have Windows 7? (It is always necessary to indicate in the first message, as well as the version of the player).I would also like to know the player's installation mode. (normal or portable). Compare your system internet connection settings, maybe something is blocking the connection to this stream.Look at the player settings, and try changing them.Read more...To avoid comparing the settings of both players, you can transfer the settings file from the user folder.Close the player (with a working radio), copy "AIMP.ini" file and replace it on another computer. The best to do this:Install the player on the computer (where the radio is running) in portable mode. You can even put it on a flash drive.Read more...check that the radio is working properly, Then, transfer this portable version of the player to another computer and test it there.With these actions, we'll find out- Is there a problem with the player (or its settings)- Is there a problem with the OSIt is also possible to perform a portable installation, on a computer with an inoperative radio, and compare the work of the normal and portable version of the player.To run two versions of the player simultaneously, add the "/DEBUG" parameter to the startup shortcut.Read more...
#EXTM3U#EXT-X-VERSION:3#EXT-X-STREAM-INF:BANDWIDTH=131192,CODECS="mp4a.40.2"chunks.m3u8?nimblesessionid=8851467
Good.Now, download this playlist every (via) 10 seconds and compare entries in the inside.https://en.wikipedia.org/wiki/M3Uhttps://en.wikipedia.org/wiki/HTTP_Live_Streaming
