Refer to Misc menu and select the "find missed files" menu item
If you think of the "Misplaced files..." option in Music Library, it doesn't seem to get the job done easier and faster than updating the whole library again.Since there is a lot of dead files, there is no option to replace all paths at once, instead, I can only change files 1 by 1, when I select a bunch of files and point them to another (new) folder, updating takes as much time as updating library...
Is there any way to open the Local.adb file as a text file and replace paths:For instance:D:\Music\Song 1replace with:A:\Guitar Music\Song 1
Anyway, I think the "replace path" feature will be so useful for music library and playlists, I will implement it in one of future version of player
