AIMP for Android v4.00
Tracklist export template is broken with adding '%' any solution?
Topic: Tracklist export template is broken with adding '%' any solution? (Read 856 times)
June 08, 2021, 14:15:59 »
farrukh
Following is part of my template for exporting tracklist, i want to add % to width=100
should look like this:
width="100%" frameborder="0"
but when i add percentage symbol '%' it breaks the template and exported tracklist is incomplete. Kindly guide me how can i add this symbol to make it work properly.
<div class="list-group">
<div class="list-group-item active" style="font-size: 17px;"><center>Preview</center></div>
<iframe src="
https://example.com/genre/song/id=
" height="150px" width="100" frameborder="0"></iframe></p>
<div class="list-group-item active" style="font-size: 17px;"><center>Tracks</center></div>
Re: Tracklist export template is broken with adding '%' any solution?
June 08, 2021, 20:18:04 »
CkopoxoD
Карма: +68/-0
You can add any symbol by its code:
Code:
[Select]
%Char(37)
June 09, 2021, 11:00:24 »
Супермен
Карма: +2929/-56
% is reserved for macros. CkopoxoD is right, this is a workaround.
June 18, 2021, 18:12:37 »
farrukh
Thank you so much brother 'CkopoxoD'. That worked.
